I've now realised that when i fill my car up it leaks.. but if i go 3/4 tank i dont think it does.. havent checked what the problem is... figured i would come here and see if anyone has had a similiar issue..
Fuel Leak problems?
Re: Fuel Leak problems?
X2 is it dripping when you fill it up to full, can you smell fumes, is a little lepracon sneaking up to your car at night taking fuel out, hows the ring seal on the top of the fuel tank, check your fittings going to the tank and at the fuel filter ,check the engine compartment also on those lines and the fuel injector O-rings, look for drips, don't check for drips with a lighter or match, good luck were all counting on ya.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by ssms5411 View PostX2 is it dripping when you fill it up to full, can you smell fumes, is a little lepracon sneaking up to your car at night taking fuel out, hows the ring seal on the top of the fuel tank, check your fittings going to the tank and at the fuel filter ,check the engine compartment also on those lines and the fuel injector O-rings, look for drips, don't check for drips with a lighter or match, good luck were all counting on ya.Wait, Is that a V6 or V8?
Originally posted by ACiFiC View Post2000. it drips near the muffler<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a><br /><a href=\"http://www.chitownracing.com\" target=\"_blank\">www.chitownracing.com</a>
driver side/passenger side? Where is it running from? This question and responses are so vague. Little more help is needed from you. We can do all the help we can with alot of info. and hardly none with none.lol.:wavey:
sorry like i said i havent had time to look at my car in a while.. just thought i would ask incase anyone has had this problem before.. its passenger sideWait, Is that a V6 or V8?
Originally posted by Bird_Of_Prey View PostThe only way you can have a fuel leak on the passenger side is if the tank is cracked.
its a 2000.. but then its only cracked at the top because as long as i only fill 3/4 tank im fineWait, Is that a V6 or V8?
Maybe the rubber ring seal is leaking when you have a full tank it soloishes around and leaks out the top rubber seal.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
You'll have to get under there while it's leaking and trace the leak back to its source. If the leak goes beyond where you can see, you have to drop the tank. I would not recommend cutting the access hole to check the ring seal because if there is a spark.... well, you know.2002 Silver Firebird A4<br />T-Tops, Leather, Y87, W68, Chrome Wheels<br />Bone Stock
