ignition key position sticking - FirebirdV6.com/CamaroV6.com Message Board
  • ignition key position sticking
    any clue on how much it costs to replace an ignition column on the 2000 fbodies? Mine's sticking and had a locksmith just use WD-40 on it and said that's all he could do for me. Thanks
    2000 Y87 Bird M5 with mods<p><a href=\"http://www.vzavenue.net/~ngeorg/\" target=\"_blank\">http://www.vzavenue.net/~ngeorg/</a>
    Are you serious? A 2000 and your ignition is going out already? Are you sure it's just not the steering wheel lock? I don't mean to insult your intelligence, but that seems to puzzle a lot of people. After removing the key, if you turn the wheel it will lock. Then when you re-insert the key, it won't turn unless you turn the wheel a little bit. I'm not entirely sure what you're speaking of meaning your ignition sticks....??? I would think with a 2000 it would still be covered under warranty.
    Nitrous is like a hot chick with an STD....you wanna hit it, but you\'re affraid of the consequences...<br /><br /> <a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=244935\" target=\"_blank\">http://www.cardomain.com/member_pages/view_page.pl?page_id=244935</a>
      If you have an automatic and the key sticks in the ignition then you have to adjust a thing under the shifter plate. You can find it on this board by searching for it.
        same thing I posted under "has this happened to anyone else"
        -235/4517 Chrome Mondera Solaris<br />-Hornet remote start-keyless entry<br />-Pioneer 8400/CD/MP3<br />-2 Audiobahn 10\'s in custom box<br />-Flowmaster exhaust-SLP CAI-*180<br /><br />Never underestimate the predictability of stupidity....Tony from \"Snatch\"
          ya the bad boy sticks in the 'on' position when i try to shut the engine down. had the locksmith come out and take a look, he lubed it up with WD40 and said that's all he can do with our ignitions. Unfortunatly the warrenty ran out a month ago, but i think my insurance will cover it. the locksmith said the ignition alone costs around 400 bucks, not sure about install costs, ugh!
          • Andy H
            Transmission removal help!!
            by Andy H
          • 2.8 Bird
            Abs inop
            by 2.8 Bird
          • fishin
            by fishin
