oil pressure fluctuates - FirebirdV6.com/CamaroV6.com Message Board
  • oil pressure fluctuates
    took a quick clip of how my oil pressure fluctuates. although the vid doesnt show how sever it gets. it can drop from 60 to 30 then to 90 and back to 60. idk what is wrong so i was hoping someone can give me an idea. i changed the oil pressure switch about an year back. the problem shows more towards the end of the vid.
    http://s151.photobucket.com/albums/s...t=VID00006.mp4
    Re: oil pressure fluctuates
    Aftermarket oil pressure sending units tend to be more sensitive to changes and tend to show a higher reading than stock units. It's kind of hard to tell from the video, but it looks like it raises under acceleration, which is pretty normal. It just seems to be moving more than your original "dummy" unit allowed.
    Try hooking up a mechanical oil pressure gauge and see what it reads.
    '99 Camaro
    '04 Saab 9-3 Aero
    '90 Audi Coupe Quattro
      ok ill do what you suggested. is there anything major that i should worry about? and should i replace it the sending unit? and it does raise during acceleration but at idle it "jumps" back and forth
