Anyone have this problem? Anyone know how to fix it? Thanks.
Belts making whining noise
1993 3.4 <br />Borla rear section<br />3 inch Catco High Flow Cat<br />2.75 inch I pipe (Picked one up from an LT-1 guy for a whole $10)<br />K&N Fipk <br />180° T-stat<br />Jet Stage II<br />10 Spoke Z28 Wheels<br />NGK\'s, Taylor Spiros<br />Mobil 1 synthetic<p>Email Viper2@chesnet.net for 4th gen replacement parts.Tags: None
Clean or Replace the belt that is on there or replace the idler/tensioner pulley and realign it to the belt.
I recommend a good cleaning - it usually helps a good bit!2002 5-spd NBM Camaro
Details: www.1lev6.com
Mine did it slightly, then recently I hit 50k miles so I replaced the belt. Yeah... it makes even more noise now. I haven't decided on where it's coming from, but until I can definately tell, I'll just leave it. It makes a cool noise anyways. Had someone completely believe that I had a SC under the hood.
Do you have an aftermarket air intake on your car? When I replaced my stock airbox with the ram air kit for my new hood I noticed a couple whineing noises. After a couple screws were tightened and a couple gaskets checked, no problemo.
Ryan1997 Sebring Silver Metallic<br />Camaro RS A4<br /><br />Mods:<br />Aluminum Driveshaft, Z-style hood, headers, B&B Cat Back, fan switch, BMR Suspension, Silver Gauges w/blue interior lights, Clear Corners and Sidemarkers, Power antenna, 18\"x9\" OZ Superleggera Wheels
