So I have two issues that happened at the same time.
1 - The AC went out, I am sure there is a leak as we re-charged the system and it was empty according to my gauge 4 hours later. Sucks, but I'll drive with the windows down and bake in the Texas heat...
2 - Coolant leak, last week I started running a bit hot. I added about a half a jug of coolant yesterday and it has been doing better. I noticed when searching for a possible freon leak last week that the lower passenger side of my engine was wet. Before I knew my coolant was leaking I thought it was freon, or oil from the ac system spraying out. So my question is does anybody know of what could be leaking on the lower passenger side of the engine?
It's a 97 Camaro, I replaced Upper & Lower intake manifold gaskets within the past year, have not seen any milkshake oil.
My fear is the head gasket has failed, but wouldn't that cause oil/watery mix in my oil?
Appreciate any suggestions or help.
