Dave Buckshaw is gonna prgram my computer. Is it a good idea to get it programmed so that the knock sensors are turned off? What all could this hurt?
Should I hav my knock sensors when I get my cmputer progrmmed turned off or on?
Longtubes, true duals, ram air, caspers tps tec, ls1 26lb injectors, supersix powerpack, heads milled .020, comp cam .507 220/224 114 ls, forged internals and chromeoly pushrods, bored .030 over, tb spacer, tranny built with stiffer springs and kevlar bands, bigger servo, transgo stage 3 shift kit, edge 3600 stall, 1 pc aluminum ds, 3.73 superior gears, lsd rear ,custom pcm tuning, walbro 255 in tank,Tags: None
well it depends, if your getting knock and you get it for to long your car wont compensate for timeing to keep it from continuously knocking SO if you get to much knock the car will poof on you if the detonation is bed enough.... course then again with extensive mods and large cam you could get the knock sensors to pick valve train noise up as knock... so over all its your choice me my self would turn them off.. older cars never had a prob like this... and when they did .. they fixed it :D91 Eagle Talon Awd Turbo 5 speed FOR SALE 6000$<br />Looking for a Fiero GT<br /><a href=\"http://www.swdsm.net\" target=\"_blank\">www.swdsm.net</a>
