Missing During Acceleration - FirebirdV6.com/CamaroV6.com Message Board
  • Missing During Acceleration
    So about 2 days ago, i was driving home and my car whenever i pushed the gas it would start missing and back firing. So i thought i got some bad fuel so i used this stuff called HEET to hopefully get whatever bad was in it out. Well that did not work. So i was told to replace the fuel filter. which i just did and now my car is idling even worse and its still back fires and misses under acceleration. Do any of you have any idea what the problem could be? ( EX the coil packs or maybe i need to sea foam my car IDK) any suggestions would help. Thanks
    Re: Missing During Acceleration
    Probably a clogged CAT. I was having the same exact problems (my SES would flash when trying to accelerate hard). I replaced my fuel filter, ignition wires, had my intake fully cleaned out, and still ran horribly. Then my neighbor, who is also a mechanic, had me rev the car while he stood behind it, and sure enough, metallic 'snow' came out of the exhaust on a hard rev. I would check for that, and if you see some metallic or ceramic looking powder come out of your exhaust on a hard rev, its definitely a bad CAT. To fix, I just gutted out my cat, welded it shut, and popped in an o2 simulator so I can still pass inspection. really made the car run much better too!
      Nope thats not it my CAT got clogged about a year back so we just deleted it and put a straight pipe their.
        Just researched a little bit and came up with the MAP sensor could that be it ? I just cleaned my throttle body out and their was black crap covering the whole thing. That was about a week ago and after i did that my car had way more acceleration and power. Could the sensor be failing cause of that?
          change the plugs and wires. they are easy and cheap. Go from there.
          1997 Camaro LS1 RS
          1994 Camaro - Sold
          1999 Trans am Vert - Sold
          A Few Mods....
            did them about 2 years ago should be the problem but im going to replace the MAP sensor if that dont do it i will do plugs and wires
              what kind of plugs and wires did u use 2 years ago... but could be ur maf how ever b4 u buy one unplug it and drive around if it drive good then thats the prob "yes you can do that"
                Wait, a misfire could be a lot of things. My v6 had a ton of different misfires occur. First things first. Have the coil packs checked. These cars are famous for coil packs going out. I don't think plugs and wires would do that, unless one of them wasn't firing or some other related issue. I would do what people here have recommended, but first check the coil packs. If it's a 3.8, have fun with the plugs. They are a b!tch to get to.
                #1:1999 pewter metallic y87 rs A4 camaro.check out the pics on the link below<br />#2:Bright red 1979 Pontiac Trans Am. Brand new 400 cubic inch Pontiac Motor. All work done by me, except the engine work.<br /> <a href=\"http://www.cardomain.com/ride/2216133\" target=\"_blank\">http://www.cardomain.com/ride/2216133</a>
                  Get the car scanned first. Hard to tell what the problem is until we know what codes its popping.
                  1995 Pontiac Firebird
                    Definitely get the codes checked that will narrow it down hopefully.
                    Most of the times when I have had these problems it has been coil packs or failed spark plug wires.
                    Good luck
                      Thank you so much it is the MAF sensor............ But um their $130. does any one have one they would sell to me for cheap. Please!!!!!
                        im sure some one has one on here i have a 2000 one but they are different
                          Id like to think that you solved it, but Im getting the feeling its not figured out.
                            what do you think the prob is?
                              I don't know, I don't know what the codes are that are popping. Taking off parts and replacing them without knowing 100% is not a smart idea. You don't want to throw money at a problem.
                              Get the codes....we can go from there.
