A while ago the car had the 195 thermostat changed out for a 180 thermostat, and the PCM updated to lower the fan on/off temps accordingly. Everything is working fine, but sometimes when the motor hits about 4000 rpm, it feels like its misfiring until I do it two or three times. Then its fine for a while. Wondering if the plugs are loading up and should be changed to a hotter plug?
Change to hotter plug when going to cooler thermostat?
Re: Change to hotter plug when going to cooler thermostat?
I haven't heard of anyone swapping plugs due to a thermo change. Your engine is still going to get up to the same temps, it just takes longer as the thermo is opening sooner and fans run earlier.
Originally posted by 97rs4life View PostI haven't heard of anyone swapping plugs due to a thermo change. Your engine is still going to get up to the same temps, it just takes longer as the thermo is opening sooner and fans run earlier.
TR55's.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by ssms5411 View PostTR55's.
i went tr55's, 180 stat, and a manual fan switch before i tuned and it hasnt given trouble once.pacesetters|full 3" borla exhaust|3" stainless e-cutout|slp cai & ram intake|c/f whisper lid|tbs|eibach|kyb|stb|sfc's|adj.lca's & phb|slp fan|b&m t5|180*|z06 17x9.5|8000k hids|hptuners|d/s rotors
gone in body, but not in spirit
ive never heard my fans come on ever unless i turned them on manualy with hptuners. and i run 190-95 all the time it didnt change when i went from copper plugs to Iridium
Stock fans will come on at 220 degrees first stage an 230 degrees second stage, unless the A/C is on, reprogramed, or manual fan swwitch. If you want a colder plug thats used for FI and nitrous NGK TR6 would be it.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by bwkmaro View Postive never heard my fans come on ever unless i turned them on manualy with hptuners. and i run 190-95 all the time it didnt change when i went from copper plugs to Iridium
