Car heating up too fast? - FirebirdV6.com/CamaroV6.com Message Board
  • Car heating up too fast?
    Ok, my 00 SS doesn't overheat or anything, but it seems to be up to normal operating temperatures waaaay too fast, just wondering if someone might have an idea.
    #1:1999 pewter metallic y87 rs A4 camaro.check out the pics on the link below<br />#2:Bright red 1979 Pontiac Trans Am. Brand new 400 cubic inch Pontiac Motor. All work done by me, except the engine work.<br /> <a href=\"http://www.cardomain.com/ride/2216133\" target=\"_blank\">http://www.cardomain.com/ride/2216133</a>
    Re: Car heating up too fast?
    Define too fast? And what temp does it get up to?
      its called aluminum block end of story
        Well, it didn't heat up this fast before I deployed... not it is warmed completely up in under 2 minutes. Just seems strange. It gets to normal operating temperatures.
          Stock temps for our 3.8 is 220 then frist fan then 230 2nd fan , I would have to look at a 02' LS1 Bin and see if their about the same. I know GM has them run hot. But this is the hottest time of the year though.
            Did you drive it in this kind of heat before you were deployed? I don't know what kinda temps you're seeing in your area, but the 100*+ weather around here warms up any car in almost no time.
            '99 Camaro
            '04 Saab 9-3 Aero
            '90 Audi Coupe Quattro
              220 is stock temp? Thank god. I flushed my coolant and got around those temps.
              So it heats up to temp in 2 minutes?
                It's over 100* my suv heats up around 2-3 mins. That seems kinda normal for aluminum blocks.
                  Hmm, maybe it is the heat. It's been pretty warm here lately for Washington. Usually it's cold and rainy but we've been lucky to have weather in the high 70's to low 80's. Hmm. I'll chock it up to that. Thanks everyone. I just wanted to make sure something wasn't wrong, it just seemed too fast and not healthy for the engine.
                    check your mas.
                    in some cases it will give the engine wrong inputs and cause the engine to run lean and that WILL cause the engine to heat up significantly more.
                    thats probably not the case. but it definitely happened to me.
                      My Formula used warm up and throw heat in under 2 minutes, in the dead of winter. Aluminum is an excellent conductor of heat.
                        Alright guys. I just didn't remember it being that quick. Thanks everybody.
                          I ran mine today for 3-4 hour round trip to Prescott ,AZ. I started here in the city and it was 221 degrees on the highway on my scanner, and when I got up north it went down to 185 degrees , shows what a 2 hour drive and 20-30 degree lower temps will do. I think it was 112 here in Phoenix, and like 80 in Prescott, so nice up there. I need to move. LOL But its 5100 ft. compared to 1200 ft. difference.
