Replaced the 'state with a 160 on my '95 Camaro a couple weeks ago and it was runnin' great (of course it normally does. ;) ) Now, however, it's running great when it's moving, but God help me I have to sit in traffic! Today I was sittin' there watchin' the temp gauge go up . . . and up . . . and up . . . and up . . . . and nearly redlined!
I've heard the fan kick on while the car's idling in my lot, so I'm certain that's working.
<blockquote>quote:</font><hr>What are the chances it could just use a good flushing?[/QB]<hr></blockquote>
Go for it. It might help a little. Usually when temps go up at low speeds, it's a fan. If it was anything else, your temp would be high at highway speeds too. Your fan kicks on when you turn on your AC. It's a good way to check it out in your driveway. Just make sure it's actually causing air to move, not just making noises.
This may sound crazy, but try turning the heater on for a while. I had the same problem with my car, I'd turn the heater on, and the temp would drop. I think that it might be because of air getting stuck somewhere in the system, possibly where the temp sensor is. May also be that the radiator can't get rid of enough of the heat, and when you turn the heater on, the core acts as a secondary radiator. You can also try turning the AC on, which turns your fans on.
Wife and a dog, they both think they\'re Kujo.<br /> <br />1999 3.8 A4 Y87<br />Navy Blue Metallic<br />BFG G-Force KDWS 275/40/17s, <br />WS6 Wheels (17x9)<br />Phoenix Transmissions 2400 Stall Converter<br />FRA, Holley Powershot filter, Whisper Lid, Ported Throttlebody<br />2000 manifolds, Flowmaster, WS6 Tail Pipes, <br />MSD 8.5mm Wires, MSD Coils, Autolite plugs<br />Performance Cryogenics treated rotors<br />1LE Sway Bars and panhard rod, 1LE front springs w/SLP Bilsteins, stock rear springs w/ 3rd Gen Bilsteins, BMR STB, KBDD SFCs, 1LE rear lower control arms, 1LE front lower control arms<p>1968 Chevelle Malibu 327 TH350
