VVT 3.8L v6 - FirebirdV6.com/CamaroV6.com Message Board
VVT 3.8L v6
  • VVT 3.8L v6
    I noticed a small oil leak a few days ago, and I isolated to the oil pan gasket. I reused my old one when I built my new engine, so it was tired.
    I got the oil pan off and noticed that the remnants of oil left in it looked like nestle quick. I was about to cry. I didn't want to replace a head gasket because I had internal bleeding. You know, coolant in the oil.
    As I am draining the chocolate milk from the oil pan, I find 3 large (almost 1 inch across) chunks of something. I thought to myself: ****!!! My brand new engine is breaking apart!!!
    I cleaned up the chunks and put them together. THey were pieces of the timing chain tensioner. I have no idea how long they were like that, but I know that every time I nailed the throttle, my cam advanced itself from the centripetal acceleration acting on the chain.
    That also explains the water in the oil. THe timing tensioner bolt hole goes through the water jacket.
    I guess I am walking for a few days while I get one of these: new timing set
    I am gonna just put that thing on and hope to god that my engine isn't riddled with foreign object damage. That would suck if little pieces of the tensioner were blocking oil galleys somewhere in the block.
    As for the milky oil, I will take the car to a dealer and get an oil flush done. I should take the motor back apart and re-inspect everything, but I REALLY don't feel like it.
    Anyways, that is how to make your GM 3800 II into a VVT motor.
    I am amazed at how brutally tough the 3800 is. Huge chunks of mine have blown off and it keeps right on running, with plenty of power.
    1999 red camaro v6 M5: with a turbo<br />13.52@107.99<br />No, seriously: Who Farted? <br /><a href=\"http://www.cardomain.com/memberpage/600086\" target=\"_blank\">http://www.cardomain.com/memberpage/600086</a>
    Damn...
    1997 Dodge Viper GTS
      malice you have a 3800 series 3?
      1998 green camaro, bear rotors.<br />It\'s not how much money you have, It\'s how many toys you have.
        ??? what makes it a series 3. i have heard people talking abou it but no explaining
        2000 3.8 A4 Pewter Camaro
          its the new the new verison of the motor the 3800 series III is in the new grad prix
            o'....thanks. whats the numbers for it? hp/tourqe
              Ok I am embelishing a little bit. I just put L32 rods in my 3800II and I am calling it a series III. The new III has forged pistons and rods. The bore, stroke, etc... are the same as the II.
              My L32 rods and diamond pistons make it worthy of the III nameplate in my humble opinion.
              My variable valve timing is going away tommorrow when I install a double roller timing set.
                Here is a decent breakdown of the 3800 III
                http://www.fastfieros.com/enginesava...ew_changed.htm
                  After reading this, I probably should stop calling mine a III. All I have is the L32 rods, forged pistons, and fel pro gaskets. I don't even have Air condiditoning anymore. Hardly a III.
                    lol. thanks for clearing it up
                      Still trying to find oil leak
                      2 days ago
                      Getting some work done on my truck
