Re: I'm about to give up.please help!!!!
Im not talking about a PCM scan, I'M talking about a full diagnostic. A full diagnostic is MUCH more than just scanning for codes. You can literally snap you crankshaft in half, and not pop a code. Engine will not run afterwards, but you can scan the PCM and you could possibly not popped one code. You can shoot a piston thru an oil pan.......and not pop a code. You know the piston dropped thru, you can see the thing hanging out of the oil pan, but you could possibly not pop one code.
The PCM is only going to know whats wrong with ignition, timing, fuel delivery, and whatever electrical that is being monitored. It can't tell you about full mechanical failure of certain parts. Its like trying to scan the PCM for a rear main leak. PCM isn't going to tell you ****, but you see the oil on the ground, you know something isn't right. I mean hell, I have a trans that slips when WOT, and I have NO codes pop from that. I KNOW its a mechanical failure, the only way to determine the exact failure is to have a full diagnostic ran. Scanning codes is not going to tell me what is wrong with my slipping trans, nor is it going to tell you exactly what the vibration is coming from, unless you have a failed PCM, or a burned out SES light.
Originally posted by Richardcoelho
View Post
