****QUESTIONS**** - FirebirdV6.com/CamaroV6.com Message Board
****QUESTIONS****
  • ****QUESTIONS****
    One:
    i have a power steering leak but i cant tell where it is coming from and i dont know what is a power steering hose or not i dont know what the power steering pump looks like. i have trouble seein things around there. does anyone have a diagram of the system or pics of the pump?
    Two:
    the two hoses on the passenger side going into the motor below the alternator with white ends. it has coolant going threw it. what are these hoses.
    [img]graemlins/popcorn.gif[/img]
    2000 3.8 A4 Pewter Camaro
    The power steering pump is at the driver side, FYI. There are two hoses connected to it. One leads to the rack and pinion and the other one leads to the power steering fluid container.
    <i>00\' NBM Firebird~T-5<br />60\': <b>2.29 sec.</b><br />1/4: <b>14.7 @ 95.5 MPH<br />Ask not what your country can do for you, ask what you can do for me.</b></i>
      i know its on the driver side and i can follow the hose to a point but then it gets tight and dark. i need to use a flash light [img]graemlins/twak.gif[/img] . but thanks, now i know theres only two hoses :D
        the two hoses on the pass. side are for your heater core. they have coolant run through them at all times. I blew the crap out of one of them once, a plastic fitting at WOT exploded on me. connected the two broken ends with a larger piece of rubber hose.
        oh, those white caps are a PITA to get off. you gotta like twist them 1/4 turn, the pull on a weird angle and wiggle......
          the only reason im asking is cause if i barely touch the hose, coolant seeps out of them. not the best seal.
            You can't see the end of the pressure hose for the power steering pump unless you get under the car and look behind the pulley. I just changed mine yesterday. By taking the belt off I was able to get a wrench on it, (barely). $12 at autozone,
            95 convertible 3.8 series II
              what was $12?
                http://f1.pg.photos.yahoo.com/ph/cor...&.dnm=3169.jpg
                These are from your heater core.
                http://f1.pg.photos.yahoo.com/ph/cor...&.dnm=c597.jpg
                Hope this helps!
                95 Camaro 3.8L Y2K motor <br /><a href=\"http://www.cardomain.com/id/coriya71\" target=\"_blank\">www.cardomain.com/id/coriya71</a>
                  thanks
                    where did you get that?
                      I got a 6 disc set from my brother-in-law. It will pull up specs from alot of GM cars.
                        cool. i wish i could find a web site with stuff like that
                          The power steering hose is 12.00. Sorry not being more clear. Have you fixed the leak?
                            not yet. its finally cool enough here today so i can work on my car and not have a heat stroke.
