in reference to this thread: http://forum.camarov6.com/showthread.php?t=101865
does NOT happen by "just a few drops" of water.
hydrolocking comes when water FILLS the combustion chamber and prevents the piston from compressing it, so the engine locks up, and is usually destroyed.
it is almost physically impossible for 1 or 2 drops of water to cause an engine to hydrolock... seriously think about it.. how many people on this forum have had bad head gaskets and were BURNING coolant? There is even a post currently saying that there is massive amounts of white smoke coming from the exhaust after a head gasket replacement.. im sure this is more than just a drop of water.
back in the 50's,60's,70's it was common practice to pour water down the carb while the engine was running. the water would instantly turn to steam and break the carbon off of the piston.
it is not really recommended to do this, because water is NOT compressible, and does have a higher chance of hydrolocking the engine.. but seafoam can also hydrolock an engine. seafoam has less of a chance at doing it because it is combustable, but i guarantee if you dump too much seafoam into the engine at once it can and will hydrolock, it is not that much safer than water.
i hope i have cleared up some of the common misconceptions of hydrolocking an engine.
