What is wrong with my car? - FirebirdV6.com/CamaroV6.com Message Board
  • #16
    Re: What is wrong with my car?
    Pulled all the plugs, they are fine.. they have -1000 miles on them anyways and the cables as well (MSD cables, TR6 plugs)... Car is @ 99xxx MI if it helps anything.
    Wait, Is that a V6 or V8?
    • #17
      bump, really need this solved.
      • #18
        Originally posted by ACiFiC View Post
        Update: got a bunch of codes now..
        p0300 - Random Multiple misfires
        DTC P1120 Throttle Position (TP) Sensor 1 Circuit
        DTC P1220 Throttle Position (TP) Sensor 2 Circuit
        DTC P1221 Fuel Pump Secondary Circuit Low
        DTC P1516 Throttle Actuator Control (TAC) Module Throttle Actuator Position Performance
        What do i do?
        Looks to me like you should try a throttle position sensor.
        • #19
          Does that require replacing the whole TB?
          • #20
            depends on the TB, the electric you have to, which unfortunately you prob have right?
            • #21
              Never really investigated, i have 00' Maro, so i think i would have too.
              • #22
                yea probably thats what i have and its electric, it wont have a cable
                • #23
                  Guess i should be looking for a new TB? lol.
                  • #24
                    maybe, im not sayin its your problem im just sayin its electric lol.
                    • #25
                      sigh, did your TPS go out?
                      • #26
                        no, at least not yet lol.
                        • #27
                          I will ask around but i think i still need a coil pack, just wish it would tell me what cylinder specifically.
                          • #28
                            Originally posted by Red&Black_Attack View Post
                            Sounds like a coil to me also. My car did this when I had a wire off one of the coils.
                            You can check by pulling a wire from a coil one at a time (NOT while its running, getting shocked by a coil doesnt feel good, lol)and see if it changes when you take the trouble coil wire off. If no change or no obvious coil spark it's likely that puticular coil you pulled the wire off, if it does change then it's probably something else.
                            Have you tried checking the coils?
                            What do i do?
                            It could be your TPS sensor if you have checked the coils.
                            -Jarred '70 Pontiac LeMans | '89 Firebird Formula 350
                            • #29
                              What do i do?
                              You get these codes, and determine its a coilpack?
                              1995 Pontiac Firebird
                              • #30
                                Im gonna go with TPS on this one.
