What is wrong with my car? - FirebirdV6.com/CamaroV6.com Message Board
  • #31
    Re: What is wrong with my car?
    what about the fuel pump secondary code what does that mean? or the
    Throttle Actuator Control (TAC) Module Throttle Actuator Position Performance im
    pulled the TB off, has like some black **** stuck on around the inside, should probably clean inside my uim and lim
    Wait, Is that a V6 or V8?
    • #32
      Update: replaced the TB.. still doing this.. I guess coil packs now?
      • #33
        Originally posted by ACiFiC View Post
        Update: got a bunch of codes now..
        p0300 - Random Multiple misfires
        DTC P1120 Throttle Position (TP) Sensor 1 Circuit
        DTC P1220 Throttle Position (TP) Sensor 2 Circuit
        DTC P1221 Fuel Pump Secondary Circuit Low
        DTC P1516 Throttle Actuator Control (TAC) Module Throttle Actuator Position Performance
        What do i do?
        Did you ever try the throttle position sensor? I didn't see in the thread where you did. To me that looks like the most obvious thing to start with.
        • #34
          Yeah, i had replaced the throttle body with a different one.
          • #35
            Can you post a list of what you have tried?
            • #36
              Coil packs which stopped the miss firing but now i have
              and the reduced engine power which i didnt have before and this kind of whistling when foots on the the throttle
              • #37
                Vacuum leak. Has to be a vacuum leak somewhere. Start checking vacuum lines and around the UIM, LIM, TB gaskets.
                1995 Pontiac Firebird
                • #38
                  I know this is stupid question but where am i looking for the vacuum line?
                  and just threw a in a new TB gasket with the tb spacer that should be find.
                  • #39
                    they are all over the engine bay just start listening for a hissing sound to find a break or leak. also read up on google or youtube or just about anywhere on how to check for a vacuum leak. any vids of the car running?
                    Dave:
                    00 Supercharged Camaro - RIP
                    97 Turbo Camaro - Sold
                    • #40
                      havent got around to taking a another recent one, i could do that today, but the thing is, you only hear it at certain rpms, so need a second person, will get try to post for today.
                      • #41
                        Would a vacuum leak cause my reduced engine to go off, it only goes off after i give it 1/4 to 1/2 gas or about 5 minutes
                        • #42
                          You can also try spraying some starting fluid around different areas of the engine while it is running and listen for the engine speed to pick up a little. This can help you narrow down the area of the leak.
                          • #43
                            Take a look at these two videos.. see what your thoughts are, thanks in advance.
                            http://www.youtube.com/watch?v=yLXKXWJTKE8
                            http://www.youtube.com/watch?v=rRLdsSgGCkw
                            • #44
                              Definitely a vacuum leak.
                              • #45
                                would that cause my reduced engine thing?
