how do I get the - FirebirdV6.com/CamaroV6.com Message Board
how do I get the
  • how do I get the
    drainchuck out??? Is it a screw or pull deal? I'm trying to flush my radiator and that damn plug on the radiator just won't come out!!! I've tried turning and pulling with no luck. I don't want to turn it too hard, for fear of breaking it. But if that is what I must do, then I reckon I am gonna have to turn it...
    Stephen Cruikshank<br /><br />Selling some stuff so all I have left is the FRA, !MAF Screen, whisper lid, Holley PowerShot, 3\" catback, and 160* thermo on the car<br /><br />I Practice Street S.M.A.R.T.S. - do you?
    i had the same problem. they screw out. get a pair of pliars and grab the draincock, that's what I did. once it's started, it's easy
      k...thanks!!!
        Where's the drain **** at? Is it that thing sticking out at a angle toward the engine block and the ground from the BACKSIDE of the radiator or the thing where the hole is at on the radiator gaurd sticking DIRECTLY down from directly UNDER the radiator...
          The draincock is typically on one of the bottom corners of the radiator - on the side facing the motor.
          smcruikshank, pliers are the only way. If it is plastic, be careful, they break off easily.
