map lights wont go off - FirebirdV6.com/CamaroV6.com Message Board
  • map lights wont go off
    my map lights on my rear view mirror will not turn off. is there some kind of electrical problem, because the guy i bought the car from had the wiring to the mirror unplugged, and he also didnt have a bulb in the domelight. when i plug the wiring part into the back of the rearview mirror, the lights turn on and will not turn off if when i close the door. i turn the map light switch on and off on both sides and the lights will not turn off.
    <a href=\"http://www.cardomain.com/memberpage/483076\" target=\"_blank\">http://www.cardomain.com/memberpage/483076</a> <br />TSP rumbler, straight pipe, corvette servo. <br />Soon - 3.42+lsd,headers, cai,
    Something is grounding out. I would check the pin switches at the doors and the switch at the rear hatch.
    1997 Camaro 3800 5-speed<br />Flowmaster 80 series catback dual exhaust w/ chrome tips and !cat mod<br />K&N Drop In w/ Removed silencer<br />Freedom Designs STB<br />Motorola Hands Free Kit<br />Code Alarm Security System<br />Eclipse 5441i and PPI Amplifier<br />Q-logic dual enclosure w/ Polk 12\" subs<br />Reflective Concepts rear fill<br />Rear Front and Fog black outs<br />20% side tint 5% rear tint
      Is the hatch shut? Is the light control on the dash below the "all the way up" setting? Just thought I'd check the obvious.
      2002 5-spd NBM Camaro
      Details: www.1lev6.com
        is your interior dimmer all the way up?
        that will turn them on also..
        ~Billy
          I had the same problem. it started to do the same thing when I turned the senitivty up on my alarm. but I don't know what thats all about and why it does that.
          40th Ann GTp 4door
            I had tp spray some WD40 in the light switches on the inside of the doors. Everytime I hit a bump my lights would turn on and I thought the car was possessd. Instead it was just a little dirty ;0
            Shrug
              EXACT same thing happened to me last week. Turned out to be a short to ground on circuit 149. Here's a link when I posted my problem....
              http://web.camaross.com/forums/showt...hreadid=120978
              <a href=\"http://www.cardomain.com/id/marky82\" target=\"_blank\">http://www.cardomain.com/id/marky82</a>
