I've asked and no one has answered will i see any signifigant gains if i port and excrude hone the upper and lower intakes as well as throotle body, if i've already port and polished the heads, if so how much. Also this won;t throw my computer off will it.
lower intake
if your heads are already ported, you need to port the intake because you dont want the intake choking off the heads do you??? but dont get it too big, the BIGGEST the intake should be is as large as the intake port on the heads....<b>Black</b> 1998 Pontiac <i>Firebird</i> A-4 swap<br />271.4rwhp/259.4rwtq NA<br />13.30@102.44 <br /><a href=\"http://www.freewebs.com/wickedsix98\" target=\"_blank\">www.freewebs.com/wickedsix98</a>
you won't see much if any gains unless you do a cam with it. I also don't think it'll throw your computer off.2001 Arctic White Firebird<br />T-Tops, 3.42 rear gear stock<br />Mods:K&N Air Filter,Whisper Air Induction Lid, maf screen removed, raised air box, Kumho Ecsta 712 255-50-ZR16 tires, BMR stb<br />Mods not installed yet: FTRA, SLP Lsd/Differential cover<br />Near Future Mods: HPP3, GMMG 3\" Exhaust , 1LE Swaybars, Transgo Shift Kit, MSD-DIS-4 w/ Accel Coil-Packs, Turquoise Blue Neon Underbody Kit, BMR Adj. LCA\'s, G2 Sfc\'s & V-braces, Pacesetter headers
