anyone have any ideas??? - FirebirdV6.com/CamaroV6.com Message Board
  • anyone have any ideas???
    Ok so today I went to leave to work. Started my car and it seemed to be sputtering a bit. So as I started to go it was "chugging" along and when I gave it a bit of gas the SES light started to flash. I recently sea foamed my car so could it be that the spark plugs are all gumed up or is it something more serious?
    2002 Firebird<br /> <a href=\"http://www.cardomain.com/ride/2106142/1\" target=\"_blank\">http://www.cardomain.com/ride/2106142/1</a>
    Re: anyone have any ideas???
    i would say the spark plugs are fouled up with carbon and you are getting a misfire
      If I'm not mistaken, a flashing SES light indicates misfires. Sounds like it could be a clogged catconverter, seems to happen a lot on our cars. Maybe the seafoam overwhelmed it.
        Take it to your local parts store and have them run the codes. Might be able to find some hidden codes that haven't tripped an SES light yet. But yes, plugs would be a good start on finding the cause of the misfire.
        '99 Camaro
        '04 Saab 9-3 Aero
        '90 Audi Coupe Quattro
          flashing ses....turn off, don't move it til you get it fixed
          WAWA-A-HOLIC
            flashing SES light is indeed a misfire. could be a handful of things. plugs, wires, coil(s), ICM, cat converter, engine damage, etc
            http://www.bowtiev6.com/
              I'm with Kristen, Flashing SES means that something is causing a DTC in the PCM (typically a misfire) and it is bad enough it could cause engine damage. Misfires can also cause a solid SES when they aren't as bad.
              I had a flashing SES once with the car doing similar to what you're describing but it went away after about 500ft so I attributed it to bad gas.
              Check plugs, plug wires, and coilpacks for any signs of damage or water. turn key on to make sure you hear the fuel pump priming well, and scan it for any O2 codes
                I would definitely start with the spark plugs, seafoam is known to foul plugs out. The plugs in my Trans Am were all fouled out once because of a too rich condition, all 8 fouled out real fast, and the car chugged and couldn't keep itself running without a little gas, replaced them and the car ran perfectly. Pull out one plug and take a look at it, hopefully it looks like garbage and you'll know right away its fouled out. Start small and work your way up. Hopefully its not too serious, but my guess is its just the plugs.
                1999 Firebird Y87/W68
                  exactly. get a code reader and figure out what codes its throwing. at least pull a plug and see what it looks like.
                  Dave:
                  00 Supercharged Camaro - RIP
                  97 Turbo Camaro - Sold
                    Changed the plugs and that was the problem. Thanks everyone for your reply's.
                      Glad to hear it was an easy fix! Seafoam made me think plugs right away.
                        Yea I think it just "gummed" them up when I pulled them out they were pretty bad
