oil pan removal....HELPPPPPP! - FirebirdV6.com/CamaroV6.com Message Board
  • #16
    Re: oil pan removal....HELPPPPPP!
    Originally posted by kristen View Post
    also true! that is why i replaced my oil pan gasket AGAIN when i had my tranny off last ahhahahah.
    That's exactly why I changed my gasket...tranny was already out (replacing stall converter).
    1997 Camaro RS A4
    2006 Chevy Colorado
    2003 Kawasaki Ninja ZX6-R
    • #17
      Originally posted by Rob Bell View Post
      Ok well that's good. I was starting to wonder if this was yet another area that GM cut corners on.
      i have never really heard of there being a problem with oil pans rusting.. but gm has been making them from stamped steel for 50+ years
      the biggest b!tch is getting the oil pick up on and off.
      if you twist the oil pan, the pickup is right there, it was the easiest thing about changing the gasket.. the hardest was trying to get the pan to clear the exhaust
      • Andy H
        Transmission removal help!!
        by Andy H
      • 2.8 Bird
        Abs inop
        by 2.8 Bird
      • fishin
        by fishin
