does anyone have the same problem as me. everytime im at less than 3/4 tank and im driving and start braking i can see my gauge going down but when i accellerate after the stop it goes back up. is there anything i can do to fix this
gas tank gauge
Nope, just the way that GM designed the Fuel Sender... You'll get used to it... and the weird v-shaped gas tank that reads 1/2 full but only has 1/4 left :DCheck out my stable of supercharged W-Bodies <a href=\"http://www.fullthrottlev6.com/forums/vbgarage.php?do=view&id=136\" target=\"_blank\">HERE</a><br /><b>\'97 Pontiac GP GTP Coupe</b><br /><b>\'98 Regal GS | L67 3800 Series II</b>
Yah it has to do with the way it is designed. Just fill the tank up when it is reading half a tank.My Car <a href=\"http://members.cardomain.com/tucsoncamaro\" target=\"_blank\">http://members.cardomain.com/tucsoncamaro</a> <br />3 inch flowmaster catback system, with ceramic coated pacesetter headers,3 inch cat,K&N FIPK
That is exactly how mine is, and when you hit the last empty line my car still has about 3 gallons of gas in it.2002 M5 camaro- VTR CAI, custom cat-back exhaust, battery compacitor, pullie, lowering springs, 32mm sway bar, cross-drilled slotted rotars. 1-10\" L7 in cubby.
if you have ever read your owners manle you know the tank only calibated for 13 gallons when you hit E your expose to have 2 "safty" gallons left
they did this as a trick for the brain lolwww.turbov6camaro.com
1997 3800 Series II Camaro
by ssms5411Still trying to find oil leak on my Camaro, it’s a tough one. I think it is the oil pressure sender myself. Leaking when raving and going into boost....2 days ago
by ssms5411So my truck is finally getting some work done, after 17 years, Oil pressure sensor went out and it’s located under the lower intake manifold. Have to...4 weeks ago
