leaking - FirebirdV6.com/CamaroV6.com Message Board
leaking
  • leaking
    i have water leaking in my rear floor boards im assuming its the ttops. i just need a second opinion. and how do you fix the problem. car has almost 130k
    Re: leaking
    get inside the car and get someone with a hose to spray around the car until you find where it is coming in.
    it is very common for the t-tops to leak, but i wouldnt count out things like the door weatherstriping
      Re: leaking
      I had the same problem. Check your ttops for leaks but check your trunk seal. Mine was leaking and letting water get past and it would run down my back seat and into the floorboard. All I would see is water on the floor and no water trail. Remove the rear trunk seal and get 3m weatherstripping glue and glue that mother****er back on. Pay special attention to the bend by the quarter panel and bpillar. Check it again and you should be good.
      99 WS6
      13.25@104.97 - Lid + soon to be more other stock items ;D
      Originally posted by camaroextra
      tears are great lube, but its hard to get a girl to cry onto her own ***.
        Re: leaking
        yep. this is where mine was leaking once.
        Dave:
        00 Supercharged Camaro - RIP
        97 Turbo Camaro - Sold
