MY camaro96 v6 is sputtering every so often while driveing. wheni say so often i mean every time i drive. it only sputters when i press the accelorator in mid rpm range in any gear. i dosent sputter in neutral only when in drive. i have no MAF screen could that be the problem?? Please HELP
Sputtering wihle driveing Please HELPPPP
Re: Sputtering wihle driveing Please HELPPPP
Sounds like coil packs, but it's always nice to have a maf screenWait, Is that a V6 or V8?
Change the spark plugs and wires. If that doesnt fix it its most likely the coil packs or ICM (ignition control module). And put your MAF screen back in.sigpic
1997 Camaro RS A4
2006 Chevy Colorado
2003 Kawasaki Ninja ZX6-R
Originally posted by Shodown View PostChange the spark plugs and wires. If that doesnt fix it its most likely the coil packs or ICM (ignition control module). And put your MAF screen back in.
Originally posted by landj View Post2nd on the plugs and wires. I had same problem, hesitation and studdering and new plugs and wire cleared it right up. Forensic analysis pointed to a corroded wire connection (probably from spraying the engine down with degreaser and getting some water forced in there).
same thing happened to me in June. 54,000 miles and it had never had a tune up or spark plugs changed....
sounds like you need new plugs and wires.In America's Hat!
1997 Camaro 30th 'vert... GT1 cam/C6 wheels/Flowmaster/HIDs/Viper 2 way alarm/Alpine audio mods up the wazoo
2005 Equinox LT... mostly stock daily/Thule snowsports roof system/sound + interior mods
by Andy HHey everyone! I've been trying to remove my transmission for two days now! I need to replace the clutch. Only thing I've got left holding the transmission...2 weeks ago
