I have a 1996 v6 3.8 and ive been having trouble with sputtering and power loss idk what to do. i have chaged the spark plugs an ignition coils.
some times it only sputters when in drive but ocassionaly does in park or neutral. PLEASE HELP
Thank you
its a clear plastic thats usually in the middle of the fuel line, look at it. If it is old, chances are it would need to be replaced anyway. Its a cheap easy fix
In America's Hat!
1997 Camaro 30th 'vert... GT1 cam/C6 wheels/Flowmaster/HIDs/Viper 2 way alarm/Alpine audio mods up the wazoo
2005 Equinox LT... mostly stock daily/Thule snowsports roof system/sound + interior mods
i may be wrong, but i thought my fuel filter was made of metal, and its located by the back drivers side wheel
the fuel filter is just in front of the rear axel and i just took it to my trusted machanic i dont wanna fuge any thing up. Hopefully it turns out to be just the fuel filter. thanks anyways guys. ur all great help
