How do I look for a short? - FirebirdV6.com/CamaroV6.com Message Board
  • How do I look for a short?
    Something is draining my battery on my Fiero. I had my battery replaced last week because it was completely drained and can't be charged anymore. My new battery is still being drained and I can't figure out why or where the short is coming from.
    Re: How do I look for a short?
    How quickly does it drain? If it's noticeably drained just overnight, I would start by pulling all of your interior fuses, and if the drain is still there, then you know it's not after your fuse box, if it doesn't drain, then you can start eliminating things one at a time using your fuse box... either way it's the quickest way I know of to start eliminating things...
    other than that it's a matter of visual inspection and some work with a multimeter. I'm sure there are other tricks, but doing this helped me whenever I had a short in my 89 Cavalier, which was about once a month lol
    good luck
    Custom interior...
    TEAM NoVa
      Hey thanks Tommy. I will try that.
      With the new battery it takes about 3 days to completely drain it. I will pull all the fuses out.
      How did you fix your cavalier?
        i've been going threw the same things with the camaro for years now. always had it in my head that it was probably the electic water pump or sub and amp or something. but since they are both gone now....i still have the problem. takes my camaro about 5 days to die. never really bothered me since the car never came out...
        what did you do....replace all your fues?
        WAWA-A-HOLIC
          fuses wont cause a short
          they only protect the wiring and components if you get a short or overload.
          Think of it as a throttle limiter for your electricity.
          I like using a test light or buzzer in series with the negative.
          Pull all the fuses and hook a test light in series with negative cable
          and negative terminal on battery.
          If you get any light short its between fuse box and battery.
          if no light then plug fuses in one at a time.
          When you get a light youve found the circuit with drain in it.
          Make sure everything is off and dome light bulb is pulled.
            I like that idea.
              I did a test similar to this but used my multimeter. Turned out it was the alternator, it had a short or whatever, and it was pulling about 1.5 amps.... enough to drain the battery over night.
                Just remember things like the radio and pcm constantly draw power to their retained memory. Dont let those circuits fool you. Other than that, this is the way I do it also.
                  ditto for me here. a good test light and about 30 minutes and you should have it.
                  Dave:
                  00 Supercharged Camaro - RIP
                  97 Turbo Camaro - Sold
                  • Manimal
                    Coil springs
                    by Manimal
                    4 days ago
                  • Manimal
                    Newby here
                    by Manimal
