OK so my car has been throwing a code saying my car is running to lean in both banks. I since have put the MAF screen back on the car and it's still doing it. I took out the MAF sensor and cleaned it real good with MAF cleaner and it's still telling me the car is running to lean. Any thoughts??
What else could be causing this code?
Re: What else could be causing this code?
Originally posted by Slowside View PostI would think O2 sensors. Bank 1 and Bank 2 I think refers to O2.
Look for a vacuum leak, even though that would probably be noticeable, just check over your lines, the fpr-map sensor line and brake booster would be most suspect. Check fuel pressure at key on, and running. Give the MAF another careful cleaning. I can't really think of anything else off the top of my head. If you have an oiled filter just installed, you may want to clean it out and redo it with less oil.
TEAM C6V6
when both codes are thrown its usually an o2 sensor... but unhook your battery and reset your codes see what happens..2001 Camaro 3.8 A4
1991 3000GT VR4
2001 Mitsubishi Eclipse GS
