No Idea AT ALL!!!! - FirebirdV6.com/CamaroV6.com Message Board
No Idea AT ALL!!!!
  • No Idea AT ALL!!!!
    So in the past week my car has been randomly not wanting to start and just acting like its dead. First of all, off subject but this might have to do with it is my security light on my dash has been on and stayed on for like the past 2 months or more. Ive looked it up and (i think it has to do with the ignition messing up right ??) also my remote (Lock, unlock, alarm, trunk) stops working and i have to re program it, then it works. but now every once and awhile at least once a day i put the key in the ignition i hear my fuel pump come on my gauges turn on and then i turn to crank the car and it just dies and i have no power i can take the key out put it back in and try again still nothing. BUT if i unplug the battery then plug it back in, the car will get power again and will start right up. What could be the reason my car is doing this ??? if you know please help thank you.
    Re: No Idea AT ALL!!!!
    wait does the engine try and crank when you start it?
    I'm thinking when you unplug the battery the computer resets itself
    In America's Hat!
    1997 Camaro 30th 'vert... GT1 cam/C6 wheels/Flowmaster/HIDs/Viper 2 way alarm/Alpine audio mods up the wazoo
    2005 Equinox LT... mostly stock daily/Thule snowsports roof system/sound + interior mods
      yes definatly its reseting its self. and no not at all just dead no power
        when you start is the security light flashing? I would start by bypassing the security chip in the key.
          No it does not, my car use to do that but it dont anymore. and how do i do that ?
            hmmm...it could be either the chip in the key or the ecu probably needs a relearn...did you ever leave the battery disconnected for a long time?? and would you happen to have 2 keys?
              i had it disconnected for like maybe 2 hours while installing my tach and yees i do have 2 keys.
                did you try out the other key to see if it does the same thing?
                  Disconnecting your battery for 2 hours shouldn't really do anything. I doubt it was that
                  In America's Hat!
                    k will
                      My 2000 impala did the same thing, everything seemed to work, then turn the ignition over and everything went dead. It ended up beeing a loose battery connection. The extra strain would apparently cause a voltage drop accross the bad connection and the computer would kill everything (I guess to save the battery or starter?). I know you said that you've disconnected the battery and reconnected it, but I'd recheck all the wires leading to and from the battery for corrosion.
                        yeah i think it has something to do with that to. thanks ill look and let ya know
                          Even though you said screw me basically in your fun tach install thread I'll try to help. P.S. I will poke fun at "rice". Common, ya had to have known someone would. Anyways.
                          I had corrosion on my battery and it did the exact same thing. And yeah a loose cable will do the same. If you have any corrosion clean it ALL up and make sure you have a good mounting surface.
                          TEAM C6V6
                            Well man all you guys do is give me **** about my car. But im trying to make it unlike any other camaro and one of a kind. In my opinion you guys should give me credit for keeping this camaro out of the junk yard and being different then everyone else. Your car is sick just like most people on here thats why i ask you guys for advice. And most of the things on my car i base off all of your rides. just saying
                            But thanks ill check that
                              I had to install a cut-off switch on my pickup's battery because it developed a short that would drain the battery in 24 hours if left parked, I simply could never find the short. It was a 99 cent switch, and when it started to crap out, my truck started to do the same thing your describing. Basically, +1 to the battery connections others have mentioned.
                              Either that or there is so much metal dust in your paint from a billion keyings that your car is the center of a magnetic disturbance.
