Possible battery problem...? - FirebirdV6.com/CamaroV6.com Message Board
  • Possible battery problem...?
    Not sure what I got here... On my 2000 SS, the last few days the alarm has kinda been going off for no reason... it'll usually beep twice and then stop, then 5 minutes later it'll do it again. I end up just disarming it in the garage. Now one of my HID's doesn't want to come on very often, sometimes it'll come on like 30 seconds or so after the other one. Keep in mind I don't have a cheap HID conversion kit, I have an OEM one in retrofitted projector headlights. I messed with it a little and my multimeter is missing in action. Could this be a possible battery/charging problem? Any ideas?
    #1:1999 pewter metallic y87 rs A4 camaro.check out the pics on the link below<br />#2:Bright red 1979 Pontiac Trans Am. Brand new 400 cubic inch Pontiac Motor. All work done by me, except the engine work.<br /> <a href=\"http://www.cardomain.com/ride/2216133\" target=\"_blank\">http://www.cardomain.com/ride/2216133</a>
    Re: Possible battery problem...?
    clean your battery terminals
      clean terminals and make sure the connections tight! when I had my bird I had to replace the metal screw thing that goes into the battery because it was stripped and couldnt get it tight.
