So I got home today and noticed puddles of coolant under my car. I'm hoping its the water pump and not a head gasket. How can I make sure that its not a head gasket and it's the water pump for sure? It's a 2000 3.8 v6 with 133k miles with the original water pump. Anyone know about how much it will cost to fix it?
leaking coolant
leaking coolant
<a href=\"http://www.fbodyelpaso.org\" target=\"_blank\">www.fbodyelpaso.org</a> A4 stock 3.42 and LSD not Y87,SLP cold air induction, whisper lid, k&n filter, flowmaster 80 series, hypertech, 160 powerstat thermostat, t/a front bumper, functional nostrils, pacesetter headers best et: 15.9 at about 4800ftTags: None
Re: leaking coolant
I just checked the oil and its fine. As soon as I started the car it started leaking coolant and it seems to be coming from above the water pump.Last edited by Fred; 11-25-2010, 01:25 PM.<a href=\"http://www.fbodyelpaso.org\" target=\"_blank\">www.fbodyelpaso.org</a> A4 stock 3.42 and LSD not Y87,SLP cold air induction, whisper lid, k&n filter, flowmaster 80 series, hypertech, 160 powerstat thermostat, t/a front bumper, functional nostrils, pacesetter headers best et: 15.9 at about 4800ft
Re: leaking coolant
Originally posted by Fred View PostI just checked the oil and its fine. As soon as I started the car it started leaking coolant and it seems to be coming from above the water pump.
TEAM C6V6
Re: leaking coolant
right above the water pump.<a href=\"http://www.fbodyelpaso.org\" target=\"_blank\">www.fbodyelpaso.org</a> A4 stock 3.42 and LSD not Y87,SLP cold air induction, whisper lid, k&n filter, flowmaster 80 series, hypertech, 160 powerstat thermostat, t/a front bumper, functional nostrils, pacesetter headers best et: 15.9 at about 4800ft
Re: leaking coolant
Double check that one of the two plastic 90* elbows aren't cracked. It's pretty common for them to dry out and break, causing a leak. They're kind of hard to see, but a flashlight and some sort of mirror (I used a dentist's flexible mirror) should give you a good view.'99 Camaro
'04 Saab 9-3 Aero
'90 Audi Coupe Quattro
Re: leaking coolant
Originally posted by pace2006 View PostDouble check that one of the two plastic 90* elbows aren't cracked. It's pretty common for them to dry out and break, causing a leak. They're kind of hard to see, but a flashlight and some sort of mirror (I used a dentist's flexible mirror) should give you a good view.Daily: '02 Black Yukon Denali
Toy: '06 Torrid Red GTO
Gone: '07 Charcoal Yamaha R6
Gone: Ex-wife, lol
Re: leaking coolant
Where exactly are these elobows located? I've got the day off so I'm gonna work on it today.<a href=\"http://www.fbodyelpaso.org\" target=\"_blank\">www.fbodyelpaso.org</a> A4 stock 3.42 and LSD not Y87,SLP cold air induction, whisper lid, k&n filter, flowmaster 80 series, hypertech, 160 powerstat thermostat, t/a front bumper, functional nostrils, pacesetter headers best et: 15.9 at about 4800ft
Re: leaking coolant
I agree with the others, it does sound like those plastic elbows, they usually break around the neck, replacements are cheap and the install isn't that hard at all.
