Hey guys, I've been getting a code, P0305 and I've replaced plugs and wires so I'm thinking an injector. I know I need to relieve the fuel pressue. My question is, which port is the fuel pressure test port? I've found one on a hose on the drivers side with a green cap, and another one on the the passenger side fuel rail. Which one would be the one I need to use to relieve the fuel pressure? Thanks!
Fuel Pressure Test Port?
Re: Fuel Pressure Test Port?
passenger side of the fuel rail has the test port. Relieve pressure by pulling the fuel pump fuse, cranking the engine a few times and then the pressure should be gone.
If you are using a fuel testing gauge you shouldn't have to relieve pressure though, it has a schrader valve in it that the fitting will thread into when you attach the gauge
by DongrossmdI’m new. I actually don’t own a Camaro or firebird. I do have a 2000 Camaro 3.8 fly by throttle and 4l60e. This is installed in a 1980 Triumph TR7...21 hours ago
