Tach Issue - FirebirdV6.com/CamaroV6.com Message Board
Tach Issue
  • Tach Issue
    K i all know you guys dont really like me but whether or not you guys bash me non stop you guys do know what your talking about when it comes to general tech, fixing issues, mods, everything and that's why i keep coming back to this site. so saying that please help, cause one of you gotta know how to fix this.
    This just started about 5 hours ago and is still happening anytime i accelerate more than just normal my tach (in the dash) and (5'' tach) JUMPS AROUND, goes to zero, to around 5000 then back to 1000 then will go normal stuff like that. Could it be a sensor, loose wires or something else also just saying this two, nothing else is jumping around in the cluster MPH/fuel/temp/oil/volt just saying please if you know the issue let me know thanks.
    Re: Tach Issue
    is it just the tach jumping around or is the engine actually spinning along with those RPMs?
    1998 Chevy Camaro 3.8
    1997 Chevy Camaro Z28 - SOLD 7-23-2011
    1996 Chevy Camaro Z28
    2001 Pontiac Firebird Formula
      Re: Tach Issue
      its a problem with the ground, clean the ground and it should work
        Re: Tach Issue
        That would be my suggestion.
        In America's Hat!
        1997 Camaro 30th 'vert... GT1 cam/C6 wheels/Flowmaster/HIDs/Viper 2 way alarm/Alpine audio mods up the wazoo
        2005 Equinox LT... mostly stock daily/Thule snowsports roof system/sound + interior mods
          Re: Tach Issue
          Na its just the tach jumping around. and alright were will the ground be? is it the one under the dash on the drivers side?
            Re: Tach Issue
            My guess would be the ground for your aftermarket tach. It is probably messing them both up. A simple way to test would be to unhook the aftermarket one all together and see if the stock in dash one works correctly.
              Re: Tach Issue
              So both in dash and your monster tach are jumping around? Just go over the wiring where you tapped into the tach then, thats the only reason you would have a problem with the stock tach.
                Re: Tach Issue
                I recall in the post where you installed the tach, that the wire you spliced into was somewhere around the PCM? maybe it came loose check that and the grounds like mentioned.
                  Re: Tach Issue
                  nope got it off the cluster. but ill check that
                    Re: Tach Issue
                    i got your pm, im sorry but i dont know the answer to it unfortunately
