Its kinda the same question from my last post but do they make braided fuel lines to replace the ugly black lines we have?
braided fuel lines?
Re: braided fuel lines?
Check out ZZP for the idea , but their FWD lines, but you could make your own using EARLS lines.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
This is the same stuff I'm looking for, except I need to plumb a regulator in as well. You need to find lines with the quick disconnect fittings on them. If you find them, let me know! 3/8 quick disconnect for main feed, 5/16 for return.<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a><br /><a href=\"http://www.chitownracing.com\" target=\"_blank\">www.chitownracing.com</a>
If your replacing your fuel lines for looks only I don't think its a good idea unless you want to replace your lines every few years. Braided lines are still rubber inside and the ethanol in the gas will slowly eat away at the fuel line. They do made PFTE or lines that won't break down like standard braided hose, but the stuff is really expensive and the standard fittings don't work with the new type hose. HotRod did an article on braided hose a few months back.
http://www.hotrod.com/techarticles/e...ses/index.html69 Camaro 350 4spd, Full Hotchkis susp, Baer brakes, moser 12 bolt, Flowmaster<br /><br />96 RS Hotchkis STB, subframe connectors, Hotchkis LCA and adj Panhard rod, SS camaro sway bars, Bilstein shocks, powerslot rotors, Borla exhaust, rksport headers, k@nFIPK
