Oil Dipstick? - FirebirdV6.com/CamaroV6.com Message Board
Oil Dipstick?
  • Oil Dipstick?
    I have a 98 camaro with 234000 miles on the car and a motor with 144000mi. The problem i'm having is that the dipstick pops out whenever I run it hard. It seems to run ok still. Any suggestions?
    Re: Oil Dipstick?
    Check/Clean/Replace PCV?
      Re: Oil Dipstick?
      Already done! Ever have a bad valve that seems ok but is messed up internally?
        Re: Oil Dipstick?
        Not personally, no. With 144k miles, it's not outside the realm of possibility that the rings are getting shot. only thing that can cause a dipstick blow out on a stock 3.8 is excessive crankcase pressure.
          Re: Oil Dipstick?
          Guess I better get the compression tester out. I'll update soon.
            Re: Oil Dipstick?
            readings are cylinder#1-170, #2-165, #3-175, #4-160, #5-165, #6-170. Cold engine or at least it was when i was done! Hayes manual says 100psi min. with 30% difference from highest reading. I think it's ok but would love some input. Sorry for how long that took forgot I posted this.:work:
              Re: Oil Dipstick?
              Did some research just now and it looks like my reading would have been higher with warm engine. Also opening the throttle would have helped alittle. Anyone have other numbers? like 220-250psi?
                Re: Oil Dipstick?
                motor actualy had 164,000 now has 170-180,000 on it and strong as it ever was. Needs a 00-02 cam for that extra .008 in intake & .003 in exhaust lobe lift with the none log manifolds.
                  Re: Oil Dipstick?
                  What you have is a blowby. I don't think those pressurize test will tell you the whole thing.
                  What I would do is for you to plug your TB hole that goes directly to your PCV. Hard it hard again and if your dipstick pops then you seriously need new rings.
                    Re: Oil Dipstick?
                    It doesn't always blow the stick out though! You are probably right though it lopes a bit sometimes.
                      Still trying to find oil leak
                      2 days ago
                      Getting some work done on my truck
