weird starting problem - FirebirdV6.com/CamaroV6.com Message Board
  • weird starting problem
    This morning I went to start up the ol bird.
    (2000 Pontiac Firebird v6)
    it wont turn I hear a click but doesn't even knock the engine. One thing I do notice i don't know if it's common but when I turn the key the security light flashes, and if I leave the key in the on position the security light flashes.
    Battery level is just below the first yellow line. Checked the fuses and they all seem to be fine. I'm in the process of checking the battery.
    But I'm a bit concern if it's something else now.
    Re: weird starting problem
    You hear the starter click or another kind of click?
      i hear the start click, is what i do mean.
        If the starter clicks it doesn't have anything to do with the VATS (security light) system. You either have a dead battery or a short somewhere.
          do you hear you fuel pump turn on?
          WAWA-A-HOLIC
            Have you checked your battery terminals?
              Have you cleaned the VATs resistor in your key?
                not a VATS problem, sounds like the battery terminals are dirty, or the battery has just kicked the bucket
                  key is good, I'm in the middle of removing the starter for testing purposes.
                  Battery is brand new, the terminals are all clean.
                    Is the battery fully charged? this sounds familiar to me when I had something draining my battery. I went to start the car after only 4 hours and it did the same thing. It was just a dead battery.
                    In America's Hat!
                    1997 Camaro 30th 'vert... GT1 cam/C6 wheels/Flowmaster/HIDs/Viper 2 way alarm/Alpine audio mods up the wazoo
                    2005 Equinox LT... mostly stock daily/Thule snowsports roof system/sound + interior mods
                      how long ago did you get the battery?
                      its pretty common for batteries to be dead on arrival, because they sit on the shelves for so long. most of the time you can just charge it and it should work fine
                        My car does the same thing every once in a while. After trying a new starter, new battery, new cables and vats bypass nothing worked.
                        I finally mounted a toggle switch in the dash that was connected to a power source that I spliced into the small wire going to the starter. Now whenever it acts up I can just use the toggle switch to start the car
                        I know it's not a proper fix but it has worked for me and my car always starts now.
                          About 6 months ago, will the battery still show 100% charge and still be DoA ?
                          Sorry I was dealing with family issues that made me postpone the troubleshooting. lame...
                            Battery is good, starter is good.
                            Found out the the issue was with the VATS system, did the bypass with the 2 orange wires and the resister match from the key and it works just fine now.
                              do you have gas
                                3 days ago
