Hey not really sure where to put this one put how hard is it to delete the AC? What all has to be done? Any thing period would be helpful thanks.
AC Delete
Re: AC Delete
Depends, if you just want to take the out the ac compressor, condenser, and the lines, then its not bad, but you'll need to replace the idler pulley above the compressor with a grooved one and get a shorter belt. If you wanna take out the hvac housing as well then it's a little more work, you'll have to unbolt all of the bolts under the hood and then take apart the dash to remove the other bolts and pull it out the from the interior of the car. You'll need a block off panel to cover up the massive hole thats left.
If you go to autozone the p/n for the belt and pulley are:
Belt: 805k6
Pulley: 231051
(I saw this on another thread but I don't remember who posted it to give credit.)
Block off plate:
http://www.bmrsuspension.com/index.c...&productid=247
Now, the belt will rub a little bit unless you file down the area on the coolant passage.
Now, if you are gonna do this make sure your system is drained first. There are 3 bolts on the front of the compressor and 2 on the back. Then for the lines you'll just need two adjustable wrenches and take them off. The condenser just pulls out of the top after you take the radiator shroud off. The rest is pretty straight forward. Then take off the idler pulley and replace it with the grooved one, then file that area and slap the new belt on. If you end there you'll keep your heat and blower motor, but if you don't want that then you'll have to take apart the dash and remove all of the bolts and vacuum lines.
I think AC is pretty useless with t-tops but thats mainly because of where I live. I need the heat though so I didn't take out the rest of it.
Re: AC Delete
to be 100% honest....i did a delete many years ago....and no an going to put it back in this spring. i deleted just about everything. i even took the black box out of the firewall....that is the only part that i regret doing cause its gonna be a pita to get a new one back in. if your going to do...your not going to save that much weight leaving that in.
take out the compressor, condensor etc is fine and easy to reinstall.
you might think that you never want it in there again....but you will if your in my boat(keeping the car for my son who will want a/c one day lol)
your not going to loose that much weight taking that cr@p out
Re: AC Delete
Originally posted by 96blackmaro View PostDepends, if you just want to take the out the ac compressor, condenser, and the lines, then its not bad, but you'll need to replace the idler pulley above the compressor with a grooved one and get a shorter belt. If you wanna take out the hvac housing as well then it's a little more work, you'll have to unbolt all of the bolts under the hood and then take apart the dash to remove the other bolts and pull it out the from the interior of the car. You'll need a block off panel to cover up the massive hole thats left.
Belt: 805k6
Pulley: 231051
Block off plate:
Re: AC Delete
Originally posted by kristen View Postto be 100% honest....i did a delete many years ago....and no an going to put it back in this spring. i deleted just about everything. i even took the black box out of the firewall....that is the only part that i regret doing cause its gonna be a pita to get a new one back in. if your going to do...your not going to save that much weight leaving that in.
Re: AC Delete
Originally posted by Unique96Camaro View PostActually yea saturday driving to my dads house it was sprinkling and i was going like 45 mph the whole way not getting a drop at all lolIn America's Hat!
1997 Camaro 30th 'vert... GT1 cam/C6 wheels/Flowmaster/HIDs/Viper 2 way alarm/Alpine audio mods up the wazoo
2005 Equinox LT... mostly stock daily/Thule snowsports roof system/sound + interior mods
Re: AC Delete
Originally posted by 1997Canadian3.8 View PostCan't blame ya, probably get just as much water inside if the top was up.... LOL. Only been caught with my car in the rain 3 times and my top leaks like a sieve...
Re: AC Delete
Originally posted by 96blackmaro View PostI'll admit the only time I've even remotely missed having the ac is when it rains in the summer.
I wouldnt do w/out a/c very long here in Texas. Too miserable, specially when you get older, lol.-Jarred '70 Pontiac LeMans | '89 Firebird Formula 350
by Andy HHey everyone! I've been trying to remove my transmission for two days now! I need to replace the clutch. Only thing I've got left holding the transmission...2 weeks ago
