I am trying to replace my composite valve covers in my GP (L36 N/A). I have been told that the Camaro 3.8 covers fit, but in my case, I need 2 front covers (Oil filler side). Which side is your oil filler on? Or if there is some other part number I would appreciate that as well.
89017480 right side, valve rocker arm cover, 1995 "F" body.
89017481 left side, valve rocker arm cover, 1995 "F" body.
Thanks,
Shawn
3\" DP, high flow cat, u-bend & res delete, 2.5\" exhaust, STS Turbo, DHP PowrTuner
no problem. I have been polishing an extra set of covers that I have. Should look pretty good when done. I have seen some good looking grand prix engine bays though so good luck with yours.
twist, pull, pull, course, repeat and try not to break. I took mine off, as you can tell by my pics, it took a few mins, but it does come out.
Has anyone used zzp gt1 cam if so is it worth the money and time
