RPMs surge when at steady speed - FirebirdV6.com/CamaroV6.com Message Board
  • RPMs surge when at steady speed
    Explanation - between 30 and 65mph while keeping the speed and rpms as steady as possible I can see on the TAC that the rpms rise by about 100 or so and I can actually hear it through my flowmaster exhaust. For instance at 40mph and 1400rpm I can see the TAC go up to 1500 then back down again this continues about every few seconds. I had a thread on this earlier but the opinion was that it was just the exhaust. At idle the rpms are steady. Above 70 I don't see this, it starts around back when speed drops to around 65. Neither the SES or check engine light are on. Anything simple I can check?
    Re: RPMs surge when at steady speed
    Try Transmission fluid
    Wait, Is that a V6 or V8?
      Checks good, right at the top of the crosshatch. That was about an hour after I got home from work, I'll check it again tomorrow when I get to work.
        Torque converter clutch may be slipping. The faster you drive the higher pressure the trans pump makes, so it slips less.
          Hmm, didn't want to hear that. Every time I get my tax refund in something comes up. Guess I need to get it check out.
          Thanks
            Re: RPMs surge when at steady speed (Solved)
            Pretty embarassing actually, my son who also drives a 99 Firebird suggested I change the air filter - that did the trick.
            Thanks to all who replied.
