Oil Pump gear clearance - FirebirdV6.com/CamaroV6.com Message Board
  • Oil Pump gear clearance
    Hello,
    I replacing the oil pump gears in my 3800 Series II engine. When I set the new gears in the front engine cover I only have .003 from outer gear to the housing. the book says I should have .008 to point .015. The outer gear turns freely with no issue. Will this be ok or should I look for another gear set?
    Thanks in advance!!
    Josh
    Re: Oil Pump gear clearance
    If it is made for the 3.8 then you shouldn't have a problem unless your running a double roller then ZZP makes a thinner plate for the gear cover. If its spinning freely then you should be alright unless someone else knows more about it.
      Ok. we weren't sure. IT does spin freely but the clearance is off. Im going to get another set and see if they do the same. Thanks for the reply!!!
