Motor has a bout 30K car has about 120K put the PD on like 8K ago. Beat on it pretty hard at times. I used a half a can in the booster vac and only got a little smoke when I was pouring it in. Let it sit for 10 mins got a little smoke (like 30 seconds) and that was it. Car idles smoother though. Definatley a good idea for tuneup purposes.
Seafoamed the bird
Re: Seafoamed the bird
I just got done running some in my gas tank, and I've had some in my oil for about 1 tank of gas. My bottom end must be pretty clean because the oil barly changed color so far.1997 Chevrolet Camaro
L26, Pacesetter headers, SLP cai, Centerforce DF clutch, Pro 5.0 shifter, UMI short stick, 1le driveline, J&M 35mm front swaybar, UMI lca's/phb/sfc's, KYB AGX shocks, Hotchkis stb.
Originally posted by espey_16 View PostI just got done running some in my gas tank, and I've had some in my oil for about 1 tank of gas. My bottom end must be pretty clean because the oil barly changed color so far.
A friend of mine, years ago, put a bottle of flush in and forgot about it. About 400 miles later he spun a main bearing, and the car only had about 20k on it (ouch.)
Originally posted by ScottS4050 View PostI wouldn't recommend running it in the crankcase for more than about 50 miles. It thins the oil just like any other engine flush does. :poke:
