What kinda pressure do you guys get? Not sure if you followed my old oil issues, but now I'm consistently at 85-90lbs. From MAYBE 20, to 90 with one oil change.
Oil Pressure
Re: Oil Pressure
Originally posted by cam98aro View Posti get around 35 at idle, and near 60 at 2000 rpm
Did you put a really heavy weight oil in? Like 20-50, or straight 40?
That still shouldn't bump it up that much, though. I've noticed that my
pressure will run a little high, around 50-60 @ idle for the first couple hundred
miles after an oil change. How long since your oil change?
What kind of pressure problems were you having before?
Re: Oil Pressure
Re: Oil Pressure
I'm usually just over 60 and as the car warms up it will go slightly under it.
No idea what it should be, mine has always been about there?
I use Mobil 1 and a Fram filter.Last edited by 1997Canadian3.8; 04-10-2011, 09:33 AM.In America's Hat!
1997 Camaro 30th 'vert... GT1 cam/C6 wheels/Flowmaster/HIDs/Viper 2 way alarm/Alpine audio mods up the wazoo
2005 Equinox LT... mostly stock daily/Thule snowsports roof system/sound + interior mods
Re: Oil Pressure
Mine stays around 90 psi then after warmed up 60 psi , this is with RP 20/50.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: Oil Pressure
i run 10w30 in the winter and sometimes 10w40 in the summer.
if i uses a lighter weight i would burn so much oil
