Oil Pressure - FirebirdV6.com/CamaroV6.com Message Board
Oil Pressure
  • Oil Pressure
    What kinda pressure do you guys get? Not sure if you followed my old oil issues, but now I'm consistently at 85-90lbs. From MAYBE 20, to 90 with one oil change.
    Re: Oil Pressure
    i get around 35 at idle, and near 60 at 2000 rpm
      Re: Oil Pressure
      x2.
      Did you put a really heavy weight oil in? Like 20-50, or straight 40?
      That still shouldn't bump it up that much, though. I've noticed that my
      pressure will run a little high, around 50-60 @ idle for the first couple hundred
      miles after an oil change. How long since your oil change?
      What kind of pressure problems were you having before?
        Re: Oil Pressure
        Originally posted by ScottS4050 View Post
        x2.
        No, its 10-30. Its been 1100 miles, and it's not idle. It's always. And before it was dropping to 0. Never got higher than about 25. All I did differently was put in an additive?
          Re: Oil Pressure
          What kind of additive? trans.... nvm
          Wait, Is that a V6 or V8?
            Re: Oil Pressure
            i have a 3.4 v6 and i get 20-25 @ idle is that too low?...and about 60 something @ 3000 rpm
              Re: Oil Pressure
              I'm usually just over 60 and as the car warms up it will go slightly under it.
              No idea what it should be, mine has always been about there?
              I use Mobil 1 and a Fram filter.
              In America's Hat!
              1997 Camaro 30th 'vert... GT1 cam/C6 wheels/Flowmaster/HIDs/Viper 2 way alarm/Alpine audio mods up the wazoo
              2005 Equinox LT... mostly stock daily/Thule snowsports roof system/sound + interior mods
                Re: Oil Pressure
                My gauge stays slightly above 1/2 after its warm.
                I use synthetic only and a long Wix Oil Filter.
                  Re: Oil Pressure
                  Mine stays around 90 psi then after warmed up 60 psi , this is with RP 20/50.
                    Re: Oil Pressure
                    Oh yeah, it was just some Pennzoil 5/10-30 with a Polydyn TX7 additive... and its weird cuz my oil pan leaks too.
                      Re: Oil Pressure
                      x2.
                      mine does the same exact thing
                      i run 10w30 in the winter and sometimes 10w40 in the summer.
                      if i uses a lighter weight i would burn so much oil
