anyone have an idea of how to remove the bolt that hold the coil pack on? it got rounded off and i tried using vicegrips but they just keep slipping off. I wanted to buy the socket set used to removed the stripped boltsbut i cant find a set for that sized bolt that doesnt cost $+100 for a whole set when i just need one socket. any ideas would help greatly, thanks
coil pack bolt
Re: coil pack bolt
Originally posted by bigbrian442 View Post5.5 MM socket. That is the size the bolt is. Sears has them.
rdoms6 the next smaller socket i have is a 5 mm, idk if that would be too small
Re: coil pack bolt
Originally posted by firebird19_99 View Posti have the 5.5mm socket for it but the bolt is rounded off so it just slips, or are you saying they have a 5.5mm socket to remove the rounded off bolt?
Is it a 6 point or 12 point? 6 points work better. You might try a piece of paper between the socket and bolt head.sigpic
Re: coil pack bolt
File flats on two sides then redo vice grips.Drivetrain Moderator - "There are no stupid questions, only stupid people!"
2001 Pewter Firebird Y87, M5
Go Sabres!
