Assuming that the oil pickup screen is covered in sludge, it seems like it would make sense to drain the crankcase and fill it with a couple of quarts of seafoam, naptha, or whatever is recommended, and let it soak a while (a couple of days maybe?) to break up the sludge before starting it again. Then add oil and start it up, and plan on replacing filters like crazy for a while while the sludge works its way out.
what filter is that?...fwiw I'm going to try and cleanup the neon that I have so I'll be picking up powerfoam and an oil flush from Amsoil shortly (basically seafoam and an oil flush),...may want to try something like that...but I would think your pickup is probably sludged up bad as well.
The filter was an AC Delco PF52, the long version of the pump GM recommends which I think was the PF51.
To me, the way the engine is acting it is definately sludge. I probably have more money then sense, but I'm having the oil pan dropped and the front cover removed and oil pump and oil bypass valve and spring replaced. It will run me about $750 out the door. Every symptom I have witnessed points to these two actions fixing the problem. I may be wrong, but I have to go with what the symptoms are telling me. If it fixes the car I can probably sell it for $4K or so, if not in a $1-1.5K roller. I could of tried the less expensive fix of using additives like seafoam, Gunk, ATF, etc, but I have heard mixed results and believe it is only best as a last resort. Who knows if the pump and pan don't fix it I will drop in an addative as I will then have absolutely nothing to loose. Thanks for The advice and I will post the results.
Well getting it mechanically cleaned out is definitely the best, albeit most expensive, way to go. Good luck.
Sounds like I got lucky, the repair shop reported great oil pressure from cold idle to hot idle and at high RPM. They said it had about 1/4 inch or sludge in the bottom of the oil pan, but the main issue was a heavily sludged/carboned up oil pump sump screen. I will post pictures of the sump early next week. Now that the oil pressure is good, the shop is a bit worried about the sludge on the top end breaking up and eventually causing a problem.
