dead cylinder - FirebirdV6.com/CamaroV6.com Message Board
dead cylinder
  • dead cylinder
    2001 camaro. Started running really roughly, misfire code showed 300, multiple misfires.
    Checked fuel pressure, spark, etc. all fine.
    Did compression check and number 5 is totally dead, zero compression, all others are up to
    normal specs. No water in oil or oil in radiator. What does anyone think? Head gasket or
    stuck valve. HELP.
    Re: dead cylinder
    Try squirting some oil into the cylinder through the spark plug hole and check the compression again. If it improves its the rings. If not, its probably a valve.
      Re: dead cylinder
      if you have no compression on one cylinder at all the valve is stuck open/burnt/bent
      the cylinder beside it should be a little lower than the rest as well though...
        Re: dead cylinder
        Thanx, I'll see what I can find.
          Re: dead cylinder
          Looks like a broken valve spring
