Did compression check and number 5 is totally dead, zero compression, all others are up to
normal specs. No water in oil or oil in radiator. What does anyone think? Head gasket or
stuck valve. HELP.
Try squirting some oil into the cylinder through the spark plug hole and check the compression again. If it improves its the rings. If not, its probably a valve.
