ignition switch - FirebirdV6.com/CamaroV6.com Message Board
ignition switch
  • ignition switch
    Trying to replace mine without taking the steering shaft out...got the old switch out, how do I get the new cable in? and is there a certain way of putting it in there? What about getting the metal shaft back in that comes from the steering wheel side?
    Re: ignition switch
    I tried to do mine and ended up having to buy a whole new column for $80 from a 00' SS camaro. Good luck with it.
      Re: ignition switch
      whoever thought of putting it ontop of the shaft is an idiot....
        Re: ignition switch
        wow i kinda feel like a genius for doing it myself. but ican't remember to well... the process... what did you mean by new cable? if i was there i could help but everything seems fuzzy.... were you continuing to have starting problems? im abuot to make a post in tuning about injectors please give it a look guys.
          Re: ignition switch
          figured it out, just had to wait till morning when I could see and not be feeling for stuff in the dark with a flashlight in my mouth doing something I've never done lol.
          PIA...whoever thought of putting a screw in that location is an idiot...
            Re: ignition switch
            i did mine no issues. youre talking about the cylinder lock right? or the switch itself. I did the ignition lock apart and back together in about 1 hour.
            Team NoVa
            • Andy H
              Transmission removal help!!
              by Andy H
            • 2.8 Bird
              Abs inop
              by 2.8 Bird
            • fishin
              by fishin
