Three headaches - FirebirdV6.com/CamaroV6.com Message Board
Three headaches
  • Three headaches
    I am posting in this "General Tech board" because I have "three different headaches" happening at the same time.
    Both signal lights not signaling, one of the lights not turning on at all. I've tried the following without success: Wires of the aftermaket headlamps removed from the signals wiring; wiring checked, fuses checked, bulbs checked.
    While fixing the signals, I checked the coolant, it has a milky brown color. I tried to turn on the car, the car tries to start only, but there's not injection, and there's a gas smelling. I haven't checked the starter and ignition fuses, they're metalic color and cubic shaped and I don't have the device to test them.
    Do I have an electrical problem? Is it everything connected? or, Are they three different problems? Any comment will be greatly appreciated.
    Camaro99\'3.8, original spoil package (no body mods...PROUDLY), K&N, Lid 3800II, SLP CAI, Flowmaster, Z28Chrome Tips, 180* Thermostat.
    Re: Three headaches
    check your signal relay for the signal issue
    you coolant looking like someone took a sh*t in it means your UIM/LIM gaskets are toast
    3) if your not getting fuel, you shouldn't smell fuel...how do you know your not getting fuel? have you checked for spark?
      Re: Three headaches
      Signal fixed: Bad connection on the driver's side, and a replacement of flasher (under the steering wheel)
      UIM/LIM ? What's that?
      My friend, a mechanic, fix the starting problem: No fuse on "PCM Battery," fuse that is close to "fuel pump," so he put the fuse and the problem was solved. He said that maybe I removed it by accident, but I don't think so. I never touch that fuse because "PCM battery" didn't sound to me like that was the cause.
        Re: Three headaches
        Upper Intake Manifold/ Lower Intake Manifold.
        Black \'96 RS Camaro, 3.8 V6 Series II, M5, Stock 200 HP, 204K miles! Stock \'91 Firebird 3.1 V6 automatic w/ overdrive. 266,400 miles on it. \'83 Pontiac Trans Am,305 LG4, Cowl Induction,Borg Warner 5 Speed,T-Tops,Gale Banks Exhaust System:$800 obo
          Re: Three headaches
          Ah, OK. Thanks.
          • Manimal
            Coil springs
            by Manimal
            3 days ago
          • Manimal
            Newby here
            by Manimal
