balancing - FirebirdV6.com/CamaroV6.com Message Board
balancing
  • balancing
    does anyone balance their motors anymore its fairly cheap and well worth it but i never see anyone mention balancing i called a shop out of baltimore said $205 gm 3.8 so i figured id give it a shot anyone have any suggestions?
    Re: balancing
    Our 3.8 's have balanced shafts , but are you talking about rotating assembly?
      Re: balancing
      Unless there is a method I am unaware of, you have to basically put the pistons, crank, rods and flywheel on a workbench. That makes it only worth it if you are doing a full rebuild.
        Re: balancing
        im am speaking of the rotating assembly crank rod pistons etc and i am doing a full rebuild
          Re: balancing
          <Wishes he'd balanced his rattle can of a V6
            Re: balancing
            I should merge his thread with yours Warshrike. LOL This is more than Gen. Tech.
              Re: balancing
              Im very big into air cooled volkswagens, and every engine I build for myself i balance. I have never built an engine that I was afraid to spin up to 6k RPMs. That of course is on some old technology, so its worth a good bit for me to do it. On our engines, I'm not sure how much it would be worth. If you can pay someone to do it for $205 then I say go for it. Thats also considering you already have the engine out for a rebuild or something
              Team NoVa
                Re: balancing
                yes the motor has been out waiting on funds i no balancing is old school my father had it done in the 60s and we do it to the 350s in sprint cars but i had never heard of any one doin it to the 3.8 or 3.4 if anyone has done it what were the results thanks for the feed back
                  Re: balancing
                  I think Shizzel had his balanced and maybe 97RS4life maybe did his , only 2 I can think of that may have done a balance of their motors.
                    Re: balancing
                    I had mine balanced because my rotating assembly was no longer close to stock. It was an L36 with diamond forged pistons, L32 rods, polished stock crank and aluminum flywheel. My personal experience was horrible. My flywheel chunked the weight the machine shop had put on there, and you cant exactly just rebalance it right quick. If you are altering the rotating assembly then you should get it balanced though.
                      Re: balancing
                      all my rotating assembly parts are oem replacement or reconditioned i just wonder if balancing will counter act on the balancing shaft or vibration dampner
                        Re: balancing
                        Which shop did you have it balanced at? I know Total Engine Service does balancing for V6's and that's who I had plans on going with this next time...
                          Re: balancing
                          is called house of balance google them u have to call or email them better to call they take forever to email you back there in baltimore maryland
                            Re: balancing
                            House of balance is the place to go. I deal with them all the time through work.They specialize in balancing and vibration and have been balancing engines long before machine shops started too.
                              Re: balancing
                              I used Tiner machine shop.
