Performance and Temperature - FirebirdV6.com/CamaroV6.com Message Board
  • Performance and Temperature
    Now that the weather is warming up, I'm starting to notice some quirks with my Firebird. When the weather gets above 75, my bird starts performing ~noticeably~ better. The exhaust note sounds less raspy, and it pulls harder and faster. It seems to absolutely relish hot air temps. I was always under the impression that engines preferred cooler air. I'm starting to wondering if my intake temp sensor might be faulty somehow, though I don't get any engine codes. Do our engines just love being toasty? I have a Chrome Intakes CAI, and run a 160 degree thermo, for reference.
    Re: Performance and Temperature
    You have a problem. Cold air makes power.
      Where should I start looking?
        yes cold air makes power but heat in the block has to be a certain temp before fuel will detonate properly i would suggest higher temp thermo
          my 3.8 liked to be a little warmer....actually ran a bit quicker at the track wen coolant was 195, then when it was at 175
            Mine seems perkier when the engine has only been running for a couple of minutes. Then once it warms up it's back to normal. It's always been like this since new. I attribute it to the iron heads not handling heat as well as aluminum ones would.
              can someone remind me why I'm using a 160 degree thermo instead of a 195 in my 3.4L V6?
                to keep your engine cooler......id never do a 160, v6 or v8, especially on a DD. thats me though
